Fellow members, one of the areas that has taken some focus is the community interface. Nothing ever stands still and it is time to consider a fresh, new look for the site. Over the last while we have been developing a newer look that some of the moderation and admin team have been kind enough to test. There is a strong focus on providing better parity across desktop and mobile use, as that is a more common way of accessing the site.
We will always leave the existing theme available for use for those that prefer it.
In the meanwhile if you would like to try the new look and feel and let us know about any issues experienced, that would be appreciated.
To select it, all you need to do is click on your avatar in the top right of the screen, choose profile at the bottom of the list → preferences and then User interface.
You will find the theme settings there, and Victron new theme will be an option in the list.
Lastly, click save changes at the bottom to apply.
To reverse, select default again.
Am really liking it - it seems much more logical and more readable. Far easier to distinguish what is new. It took a tiny bit of getting familiar with it, as change can be difficult, but over all, it’s cleaner, simpler, and better.
@nickdb Thanks to you and the extended team for the work on this.
Thanks for the kind words. We have a mix of desktop and mobile users, desktop real estate allows more generous use of space, but the mobile view always felt a little sparse and neglected, and in my mind it needed to be more seamless and consistent across the different surfaces, especially if you have a larger device or tablet.
Thanks, I have it now - didn’t even need to force reload. The web environment behaves strangely sometimes
I do hope that - as per the original post - the old theme remains as an option for the foreseeable future. Something about the new interface - at least to me - feels “off”. I don’t quite understand some of the design decisions.
the new user interface is visually very appealing, but I find it overwhelming.
It can only be used in landscape mode on a mobile phone, as a lot of text is cut off, or considerably less information is displayed than before.
The Replies and Views section is overemphasised, in my opinion.
I’ve just switched back to the old interface again; I find it much clearer.
The interface scales based on the size of your device, so if you have a smaller interface (yours only shows three categories at the top) it is likely to truncate longer topics more than on larger ones.
The English words for “replies” and “views” are also shorter, this is further reducing the title space available.
On my iphone 16 for example, you can see the difference:
The intent was to provide a consistent view across mobile and desktop, when display size is limited there has to be a tradeoff, so something has to make room. On the old theme this is by not showing contributors. A reasonable change is to use icons instead of words for the replies and views, this would free up some space.
Can’t say I’m a fan. It also looks unfinished, especially parts like this:
I hope you can see the problems? These look like elements glued on top of eachother, not one coherent interface. Compare that to the old style, looks much cleaner:
I liked in the old design that it was possible to quickly open up a section, for example to open all latest topics through a link in the header of that section.
With the new design you have to scroll down the entire list to get to the same link. Would be nice if the header could include that link as well
