On page 9 of the pdf “rva_-_theory_on_wiring_large_systems.pdf” there is this image;
along with the following notes;
Not recommended!
• Long path from battery to
Quattro.
• When inverting, the leftward
Quattros will “see” a lower DC
input voltage.
• When charging, The leftward
batteries will “see” a lower DC
input voltage.
Other than the inverters being Phonix in the image, but Quattro in the text (which makes no practical difference i think) , do you read the text as being the wrong way around? i.e. when inverting, doesn’t the rightward inverter “see” the lowest voltage, and under charge isn’t the leftward battery going to “see” the highest voltage, and the rightward battery see the lower voltage?
@guystewart asked to be linked in on documentation issues.
