My old rather basic solar controller failed whilst on holiday so I have purchased the above solar controller and decided to purchase a mains charger at the same time.
I am about to fit these to my camper van, however I am unable to get to where the negative wires connect to the ground on the vehicle, I am thinking they must be behind the cabinets as I can see the cables run that direction. I have a couple of questions:
- For the mains charger is there any alternate option? Can I connect it directly to the -ve terminal on the battery, or is connecting it to the vehicle shell an option and will this work?
- for the MPPT charger the instructions seem to suggest that this does not need to be grounded so can be connected straight to the battery terminals or am I misunderstanding.
I have purchased appropriate cables with appropriate inline fuses it is just this last part around connecting the -ve terminal.
I am in the UK if this makes any difference.
Thanks so much
Simon
