Hey there,
I bought a boat last year that had a Quattro with the multi control, a 75/100 MPPT solar charger, a BMV display and a shunt. Then I got a Cerbo GX and a Smartshunt, getting rid of the old shunt and the BMV. Everything showed up properly on the Cerbo, except for the Quattro. It actually did show up, displaying the mains and AC loads, but many other details in the configuration were missing, and the Cerbo stating that I should update the firmware of the Quattro to at least V200 (it had 159 installed).
I got myself a MK3 cable and figured out which fw to use for my Quattro (it’s 1940, yes obviously an older model).
So I connected the Quattro through the MK3 cable to my laptop, downloaded the config and flash tools. The Quattro got recognized just fine and I did a backup of the current settings, Then running the flash tool with the proper and latest firmware file (1940209). The update procedure didn’t finish, because I made a stupid mistake: although it clearly said to remove any multi control devices, I wasn’t really aware that it was called that way, to me it has always just been the remote…
Well, the Quattro basically started blinking like crazy and wouldn’t start up anymore, despite several attempts of power-on-off cycles, config tool, flash tool, and a lot of swearing. That’s when I went through the procedure again and recognizing my mistake. After disconnecting the multi control, I attempted to flash again with the old firmware, which - to my surprise - succeeded: no errors and the Quattro came back on. But now it didn’t show up anymore on my Cerbo. It would still get recognized by the config tool and the flash tool, but not the Cerbo.
I then did the update to 1940209 again, which worked perfectly. I could upload the old settings, change settings, etc. but it still wouldn’t show up on the Cerbo or VRM. Disconnecting the multi control and changing ports also doesn’t help at all.
What’s the fix for this? Is there any?
