I have a 3-phase system with Quattro 2 with Dynamic ESS, and also solar panels with an inverter connected to AC output 1. The grid is connected to AC input 2, and a small generator is connected to AC input 1.
When connected to the grid, the entire installation works well. If the grid fails, the battery takes over properly. However, if I want to charge the battery with my generator, the full load goes directly to the generator.
I have already tried various settings, but so far the load remains entirely for the generator.
The dynamic current limiter is set to 3 A;
the AC1 input has generator grid code NO LOM.
The UPS function is currently active, but I have also tried without it.
I have also tried the weak AC setting on or off.
Power Assist is currently on, boost factor 2.
Is there anyone who has a similar installation that actually works and can give me the correct settings?
The AC Input Current Limit is the parameter that controls the AC input power and is usually set to its maximum value by default.
The minimum varies by model. For example a 5000 VA 230 volt Quattro II has a minimum AC input current limit of 6 amps when Power Assist is turned on. So you may not be able to throttle back the Quattro far enough to avoid a generator overload.
hello Lx
i am using Quattro-II 48/5000/70-2x50
and a generator capable of delivering 3x10A, but in my test phase I am currently using a max 3A limit.
If I switch off the grid with this setting and start the generator, it will supply power to the installation, and if I increase the load to 3x 8A, that is drawn directly from the generator and the battery will not provide support, not even after 5 minutes, which I would actually expect.
Thanks Kevin, so I do indeed have the quattro II 48/5000 and have enabled power assist
and I can work fine with the 6A limit
but with the test I tried, I had an 11A load on one phase and a 1A load on the other 2 phases, and then these loads went through 1-to-1 to the generator with no boosting of the battery
Today I tried something different by removing all assistants; now the battery did assist, and the generator has a load of 6A as the lowest limit the system accepts. I tried a lower setting of 3A, but the setting jumps back to 6A.
I tried a few other configurations today, but I can’t get the system to work together with DESS and a generator that receives support from the battery with a max load of 6A to max 8A if the loads in the system exceed 8A.
Who has such a system with DESS and a small generator for when the grid goes out for an extended period,
I think maybe i should have been more specific with the feedback question.
Does the tarriff for feedback vary dynamically so dess is necessary on your system?
Unfortunately, it doesn’t seem like it’s going to work. I actually chose the Quattro specifically so that, should energy prices rise so high, I would have the option to use a generator that could be fully self-controlled.
But I have already seen more questions with the same idea of having an ESS with the option of a backup generator, and there too the outcome was that an ESS is not compatible with a small generator.
