Pylontech accu rood storing sinds v3.60~86
Sinds de laatste bèta v3.60~86 is mijn Pylontech master rood. Betreft us2000. Heb er 8. Nooit eerder storing gehad systeem draait al 5 jaar stabiel. Wellicht fout in de accu, maar meldt het toch omdat het enigste wat ik veranderd heb is de laatste bèta update. De accu is 2x in storing gegaan en hersteld zich na enige tijd wel weer.
Betas have problems, you will need to rollback to a production version to see if the issue remains.
If it is unique to the beta, please post issues in the beta section. The main categories are for production versions.
Thank you.
prod version has no problem so i gues pylontech bms en venus os 3.60~86 had a communication problem. is this adressed?
Goeiemorgen @kermit8 ,
Thanks for the report.
Its been quite a while since anything was changed in Venus OS v3.60 that relates to Pylontech batteries.
Is there more information? Ie. are there alarms, or other data?
Note that there are many systems with Pylontech batteries out there, and no other reports - I expect its something specific for your system.
installation/70317
mp2 5000 8 pylontechs us2000. De master werd rood en was blocked.
gebeurd 9-6-2025 tussen 4:00 en 6:00 uur in de ochtend. Draai al een tijdje probleemloos de beta. Na dit issue teruggegaan naar 3.5x, geen problemen meer.
It was a broken Pylontech us2000 afther 5 years( model 2020). Afther sending the logs i got this message.
”Thank you for contacting us and for providing the logs.
We have reviewed your case and confirmed that the failure of your battery (SN: HPxxxxx) is due to an internal imbalance. We will proceed with the replacement of the module under warranty.”
Great warranty service Pylontech :-))
