PV Inverter meter display merged
Good day all.
Is it possible to split out the individual PV Inverter smartmeters in the UI? We currently have two smartmeters on the AC IN inverters which work fine. However, on main display they are all shown as one. Customer would like to see (as this is a big system) the values split out so he can monitor the roof and ground inverters separately.
Any thoughts or is this a feature request?
Thanks in advance!
I think there is a fine line between information on an overview page and too much information. The dashboard has always been aggregated even for DC MPPTs.
I do hear what you are saying though.
What you may need to look at is a custom dashboard in node red or some other graphic display program which is often what bigger systems use.
