Multiple smartmeter (x5) GX Dashboard
Good day Victron fans and staff.
I have a question on a large system topic:
The current setup has three smartmeters for:
1 - Grid meter
2 - PV Inverter on AC IN
3 - PC Inverter on AC IN
There are another two PV inverters on AC OUT on which we want to fit smartmeters also for full visibility. However, the question is how will Cerbo make the difference which PV Inverter is on AC IN and which is on AC OUT as there doesn’t seem to be an option to set this in settings. I am afraid it will make the sum of all 5 smartmeters under PV Inverter, corect?
How could I achieve so that the other two inverters show on the right side and also tell Cerbo that energy is on AC OUT and consumed directly by the load. In the screenshot below for example we see a LOAD consumption of 44.65KW, which in fact is much higher because part of the load is serviced by the two PV Inverters on AC OUT.
You can set a position for an energy meter (ac in or ac out)
