Hi everyone,
I’m having an issue with my PV setup where L1 is connected to an ET112 and L3 to a SolarEdge. On the VRM Portal, the readings for these phases are showing as zero, even though the total energy generated seems accurate. When I check the Remote Console, it displays the correct values for both L1 and L3.
Has anyone else experienced something similar? Could this be a configuration issue with the VRM Portal, or is it possibly a problem with how it’s reading data from the devices?
