Continuing the discussion from SDM630 and modbusTCP:
Hi Mark, You use also the HE11 as modbus tcp gateway.
Did you make special setting or use it as a straight forward Modbus server?
My MP2 GX V3.60 cannot find any Modbus TCP devices. Not even after setting the correct IP-Address in it.
I don’t see any traffic with WireShark either but the HE11 indicates it is connected to the GX unit.
Best regards, Paul
