Hello, I recently bought an Orion Smart TR 12V 18A to recharge a 100 Ah Creabest LiFePO4 battery. The problem is that I can’t charge the battery with the Orion: the charger supplies a voltage, but no current flows. I should mention that the battery charges correctly with a 220 V Blue Smart IP67 charger. I’ve already carried out several checks: upstream and downstream battery fuses, wire continuity, different Orion settings, and connecting it directly outside my circuit. But so far, I haven’t found a solution. Does anyone have any suggestions?
Hello, I carried out all the tests, and it did indeed seem that the Orion Smart was defective. I managed to return the product and bought a new one, which works perfectly.
