The following functions are desired for the Multiplus 12|1200|50 IP21 230V:
- A remote toggle switch to turn the inverter and/or charger on.
- VE.Bus Smart with the VictronConnect App to monitor Multiplus status, voltage, current, and power details.
- VE.Bus Smart with the VictronConnect App to change the maximum mains input current when applicable.
The remote toggle switch is wired to connector H. Without the VE.Bus Smart device connected and with Dip Switch 1 switched on (and Switch 6 toggled once to store settings), the remote switch works fine. Please note that a simple toggle switch is used, not the more advanced Victron Multi Remote Control panel with a current dial.
After connecting the VE.Bus Smart, the toggle switch no longer works. The Multiplus appears to turn on while the toggle switch is off, then turns off after about 10 seconds, turns back on after another 10 seconds, and so on. This occurs whether or not a phone is connected via Bluetooth or the VictronConnect app is active.
Using a VE.Bus MK3-USB device, settings were checked; for example, remote current limit control was toggled on and off without any effect. Dip Switch 1 was also switched off, but without success.
It seems these functions are conflicting. As soon as the VE.Bus Smart dongle is connected, the remote toggle switch is overruled and erratic behavior occurs. I have read elsewhere that the “last command given” (On/Charger Only/Off) should take precedence, but there appear to be unexpected ON/OFF triggers.
Does anyone know what is happening and how this can be resolved?
