Power monitor configuration on AC-out2
Hi, I’m trying to configure my system (Multiplus II + Cerbo GX) to monitor the power consumption of the non-critical loads connected to AC-out2.
I have installed a power meter on the AC-out2 output and configured the following options:
  • Settings → Devices → Shelly energy meter → Setup → Role → AC load
  • Settings → Devices → Shelly energy meter → Setup → Position → AC Output
  • Settings → System Setup → AC System → Position of AC loads → AC input & output
However, I’m not sure if I’m doing it correctly, because I expected to see the consumption value of the AC-out2 loads under AC Loads on the console, but the value shown seems to be calculated by the Cerbo GX or the Multiplus II instead.
Do you know if it’s possible to see the consumption of the non-critical loads directly on the console?
And if so, how should I configure it properly?
Thanks.
I’m attaching a screenshot in case it helps to understand what’s happening.
On the overview the “AC Loads” = Loads on AC IN and “Essential Loads” = AC OUT 1+2.
You can’t see the measurement of your AC load meter on the overview page.
So, it’s not possible to see the separate consumption of AC-OUT2?
Or would I need to use, for example, an ET112 to be able to see it?
