I have installed a remote switch button that works fine but I also want to activate the led light when pushed in. I soldered some wires for the led light but don’t want to damage the inverter so any tips on how I can connect the power to my button to get it to light up when pushed in? Measured between the H & L in hope of using the terminal to power the light but didn’t get any voltage. Victron has there own remote control paneI which has a light when activated and is just connected to the H & L port so shouldn’t there be a possibility to connect the light on just these connections? I saw this post but about a diod to protect the current flow. https://www.cruisersforum.com/forums/f14/remote-switch-for-inverter-next-level-270024.html Is the diod something I need to install as well? The current button is connected this way. I haven’t connected anything more than the closed circuit to see that the remote switch works in case of messing anything up.
I have been looking in to the possible ways to activate the remote switch on the inverter. Is there anyone who can confirm this configuration will work okay?
Related topics
| Topic | Replies | Views | Activity | |
| Remote switch connector phoenix 1200 | 0 | 45 | March 1, 2026 | |
| Phoenix Inverter 24/5000 leds not working | 3 | 106 | December 22, 2024 | |
| How to connect victron pheonix inverter control to pheonix 12/1200 inverter | 6 | 424 | February 18, 2025 | |
| Combine Phoenix inverter control VE.direct and load disconnect from BMS | 3 | 166 | October 1, 2024 | |
| Phoenix 12/3000 inverter, remote on/off and Cerbo VE.Bus | 0 | 91 | December 1, 2025 |
