Phoenix 12/3000 inverter, remote on/off and Cerbo VE.Bus
Does the older Phoenix 12/3000 inverter support being connected to a Cerbo using the VE.Bus while still supporting Remote On/Off through Terminal H? I’d like to pull data from the Phoenix while still delegating the activation to a different system using the Remote On/Off port.
The manual states that the Remote On/Off port won’t work when the Phoenix Inverter Control panel is connected to the RJ48 socket and given that the Cerbo uses the same socket, does that have the same effect?
4.4.1 Remote Control
The product can be remotely controlled in two ways.
  • With an external switch (connection terminal H, see appendix A). Operates only if the switch on the Inverter is set to “on”.
  • With a Phoenix Inverter Control panel (connected to one of the two RJ48 sockets C, see appendix A). Operates only if the switch on the inverter is set to “on”.
Only one remote control can be connected, i.e. either a switch or a remote control panel.
