Paralleling victron lynx distributors
Good afternoon.
I was wondering if anyone knows if, and how, multiple victron lynx distributors can be parallel.
I need to run 5 lynx distributors. 4 input, then the shunt then the output for distribution.
My issue is where they go I am running into a length issue. So I was wondering about paralleling them, back to back and then just connecting the ends with a spacer and a 3/8" bolt.
Thank you in advance.
You remove the black plastic piece and bolt them together. That’s exactly what they are meant to do. Lots of pictures online. If you cant connect them directly together you can make some cable of a suitable size and connect them that way. As far as the shunt goes either use a lynx shunt or make a custom connection with copper bar for a smartshunt. Using a Smartshunt is possible but takes a little more customizing.
