Lynx power in and distribution
can you use a lynx power in has lynx distribution?
This is a commercial build, and I have been given the design of lynx power in - lynx shunt - lynx power in. With the second power in being used has the distribution for the design.
will this work? and will I need to interconnect them with RJ10 cables ?
our lynx deployment
You can use a Lynx Power in as a distributor BUT you will need to fuse everything in the outlet wiring. The Lynx Distributor is better as fusing is internal and is monitored. Lynx Power In does not have RJ10 cables.
@waninaIt is usual to connect the solar power to the Lynx Distributor so that the solar charging power is measured by the Lynx Shunt. The way you have it drawn, the Lynx Shunt only measures discharge and the SOC will not increase during solar charging. This may be understood as you have shunts on each battery.
thanks for that
