Parallel Multiplus as Generator Charger
I have a Multiplus II 5000, a Cerbo GX, Pylontech US3000 batteries, and an MPPT 250/60. I would like to add a Multiplus II 3000 for Generator charging of the batteries. I want the Cerbo to control the charging of the batteries from both GX devices simultaneously. Would this work?
Please use the search function “generator”
There have already been many enquiries and solutions for multis / quattros / generators and also 48V chargers as a solution.
If you still have questions, please ask again … that’s what this is for.
Hi, you can’t parallel configure a Multi 3000 with a Multi 5000.
Both have to be the same model & firmware.
Use another multi 5000 instead.
