Can I automaticaly delay the Orion XS start for a few minutes to allow the alternator to charge the starter battery before charging my RV leisure batteries.
The default 120sec does not seem to work.
Why? You may ask. I only have a small alternator, at the moment on start it is trying to charge the starter battery after cranking, the 3 way fridge and the leisure battery. A delay would smooth things out a little. Be nice to delay the fridge as well but do not know how, other than building a stand alone time delay devuce.
As I understand it, the link joins the H and L ports to force the Orion into default mode. Charging start and stop is then controlled by the internal engine detection system. As the voltage rises with the alternator running it switches on and vice versa.
I dont know if its firmware or not, sorry. Just a user here.
I do not use the hard link, but use the software engine detection, and the only possibility is that if the engine starter battery is already at high enough voltage, then the XS starts charging the house battery.
I cant test this until April when I get back to the boat.
In the time sequence you first see a engine running detection that surpasses Vstart, which means the Orion starts without delay. The second sequence (point 5) does not surpass Vstart, it only surpasses Vstart(delay), then the Orion will start charging after the delay time has run out. If you always want to use a delay on startup, then set Vstart to 17V, so a direct start will never happen
