On an installation I’ve been using off and on for >18 months, for the first time that I’ve noticed, the Orion XS stopped charging because of “Engine shutdown”. Going into the Orion XS settings and toggling “Engine shutdown detection” to off allowed the charging to restart.
What would cause the “Engine shutdown” to occur and are there any concerns about switching off the switch? (latest firmware installed)
more details:
Day 1
Looks like Day 1 it was behaving normally but then stopped taking full power after a while.
Day 2:
The “Engine shutdown” was turned off at about 1PM on Day 2 when 0 power was observed. Orion software said "it was shutdown due to engine shutdown” or something, I found the toggle and it started charging. After a while it stopped taking power. (I was trying to get to 100% to start boondocking for a week or so)
Here are some other days from the previous weeks where the behavior was more consistent.
I did leave the van parked for 1 week prior to Day 1 where the solar was more or less even with use (fan and Starlink) where it hovered around 80% and it is hotter than usual where I am. Not sure if either of these will impact behavior.
Thanks for the help!!
Ken
