I done the switch from old Orion Smart Charger 30 A to Orion XS 50 A.
I activate the “Engine shutdown detection” switch … exactly the same as in the past (with parameter “Delayed start” set to 120sec.).
When I shutdown the engine the procedure works well … also when i start the engine … XS will start the charge … but it starts immediately and the DELAY wasn’t respected !!! I don’t remember if this happens also the first time I power-on the XS … but, in my navigations, it is normal that I stop / start the engine (I have a sailboat) … and the DELAY of the charging MUST BE RESPECTED ALL TIMES !!!
(note that I don’t power OFF the XS … it remains powered on … as it is connected always to the engine starting battery. It is powered OFF only when I leave the boat and go home).
What I do wrong ?!? And eventually why the DELAY isn’t respected ?!? What are the reasons ?!?
I’m quite sure the the older Orion Smart 30 A respect the delay all the times (both the first than the following starts).
Thanks
