I wanted to test the new emergency reverse charging for Orion xs but had no success. The new button is grey. When I click on it, there is a message that I need to activate the charger in the settings. My charger is already activated in the settings but it is switched off by remote signal.
When I disconnect the input battery, the emergency charge button becomes active which makes no sense to me.
Please enable the engine cut-off detection.
There still seems to be an issue when it’s disabled.
I already discussed it with the developer yesterday, and he’ll look into it over the next few days.
Interestingly, after switching off emergency charging, the button nevertheless remains greyed out for around 5 seconds, but then becomes clickable again. With the engine shut-off disabled, it stays greyed out.
I don’t want to use the engine shut-off, so for now I’ll wait until the bug has been fixed.
Yes, exactly. The two Orion XS units are switched on via the D+ signal at the remote input. In accordance with Ford’s installation guidelines, the first Orion is connected at connection point 1 (CCP1) and is always active when the engine is running. The second Orion is connected to connection point 2 (CCP2), and therefore downstream of the load-shedding relay. In theory, the vehicle’s battery management system could therefore switch off the second Orion if the alternator were overloaded, thereby reducing the charging current from 100 A to 50 A. In practice, however, this does not happen, because the 250 A alternator can easily handle the 100 A required by the two Orions, plus approximately 50 A for other consumers, even at low engine speeds and high temperatures.
You have to expect the alternator to be regulated down to 12.5 V at times while driving.
As we know, the Orions don’t have voltage-sensing wires for the input voltage, so when setting the input voltage cutoff, you’d have to account for the voltage drop in the cables as well, to avoid unwanted shutdowns under load. I wouldn’t want to set the threshold any higher than 11.5 V, then. But that means emergency charging won’t work until the starter battery is already very flat.
Under these circumstances, the new emergency charging function doesn’t make sense to me. I hope they’ll improve it.
If you’re losing 1V in the cables to the Orion, there’s something wrong with the wiring. The input lockout should be set below the engine shutdown detection threshold, so no current is flowing at that point. If you’re still losing 1V somewhere, then something is fundamentally wrong.
It would be great if the reverse charging function could operate independently of the starter battery voltage when Engine Shutdown Detection is disabled.
Engine Shutdown Detection does not always work perfectly in real-world conditions. Using the Remote on/off input allows the Orion XS to be controlled more reliably and provides better control over the available power, for example by enabling or disabling the charger via an external signal when needed.
In this setup, reverse charging should ideally be available on demand, regardless of the starter battery voltage, as long as Engine Shutdown Detection is disabled and the charger is controlled via the Remote input.
