Now we are getting into some cooler weather here in Australian I have a question about the Orion XS logging a Notification on the GX Cerbo - not exact words but Charging stopped due to low temperature, this is fine and working within its set parameters and not an issue with the system functioning normally. But as I consider this a working parameter and not an alarm as such is there a why of turning these notifications off or not latching so its not kept in the history as its happening on a daily basis and filling the notifications up, worth noting it does not happen with the MPPT which could be just due to the time of the day
Related topics
| Topic | Replies | Views | Activity | |
| No device state notification | 0 | 28 | 29 July 2025 | |
| Cerbo GX: Relay 1 should be triggered by SOC but it doesn't work! | 68 | 1394 | 18 June 2025 | |
| Cerbo GX input function request | 0 | 55 | 12 November 2025 | |
| Configure Cerbo GX to trigger relay upon Orion XS internal temp / charge status? | 9 | 239 | 24 May 2025 | |
| Wieder mal: JK-BMS und Cerbo | 23 | 548 | 8 August 2025 |
