Cerbo GX input function request
It would be helpfull to be able to set an input of the CGX to Disable Charging and to have another ouput with the possibility to Disable Discharging.
If the inputs are open, everything works as setup. When active (shorted via a potential free contact) the function is disabled.
This avoids building applications via NodeRed for the same functionality.
Currently the set of options is limited to pump, door open, etc.
