Orion XS Engine Shutdown settings on 2022 Navigator
I have a new Orion XS 12-21V|50A|Non-isolated installed in an Airstream equiped with Battleborn LiFePo4 batteries and a 2022 Lincoln Navigator. The XS Engine shutdown detection believes that my engine is hardly ever running. So obviously I have some things set incorrectly; here are my settings:
Alternator type: Smart Alternator
Start voltage: 14.00
Delayed start voltage: 13.30
Delayed start voltage delay: 120s
Shutdown voltage: 13.10
Is this because the “Shutdown voltage” is set too high?
Thanks!
It more likely the start one it’s not reaching that or not reaching that for long enough, or not keeping it under load… Usually 13.8v is high.
For the most part the default ones are good. Sometimes inrais the curly off a bit of the battery rests higher.
Check your wiring for contact resistance!
As an aside, you’re probably familiar with the discussion about the internal wiring of Battelborn batteries and the bug, er, “feature” that shuts them down when the plastic plate melts (see Will Prowse’s video and the fires involving other campers with Battleborn battery systems).
