Short version is, should I turn off the engine shutdown detection?
Long version:
My goal is to keep the AGM start and LFP house topped up by: solar when anchored; the alternator when running the engine; the inverter/charger when in a marina; and whichever is most expedient when house demand requires.
Reading about the OXS 1400, I replaced my old AGM house batteries with a non-Victron LFP battery and ran all charging sources to the start bank, then through the OXS 1400 to the LFP house.
For my first test, I followed the basic recommendations of various docs and videos and set the OXS 1400 input for AGM, the output for LFP, and turned on the engine shutdown detection. Now, my observation is that the LFP is not charging fully, from any source. The Victron app says the charger is off due to engine shutdown, and the LFP sits at 13.3V while the start bank is at 13.6V (which is also the output of the MPPT controller at the moment).
FWIW, I don’t think the LFP has gotten anywhere near its ~14.2V 100% SOC, even on days running the engine all day (or overnight with shore power to the Xantrex FSW 2012 inverter/charger, although I think more research on my part is needed about that).
Reading here, I think I’m seeing the recommendation to just turn off the engine shutdown detection, which I think makes sense, but I’m concerned I may be missing something important.
If all charging sources are running through the AGM start bank, is turning off the engine shutdown detection ok and the right thing to do?
Also, a follow up would be regarding that, in the Victron app, although it shows some historical event data, it doesn’t show when the events occurred, so I can’t correlate whatever it’s trying to tell me with what operations have happened on the boat. If I added a Victron shunt (or other particular Victron component), would I get better event logs with some kind of time stamps?
Thanks much, I appreciate your time and assistance.
