I have a system with a 12V AGM starter battery and alternator (max about 14.4V), and a 3kWh 24V house battery (LFP). I’d like to leave an Orion-Tr 24/12-5 connected at all times from the house battery to the starter to keep the starter battery from going flat. The 24/12-5 is listed as having a 12.7V output, which sounds fine.
Any issues with this? Can I leave the Orion connected to the starter system even when the alternator is running, or do I need to disconnect it? I could put a big Schottky on its output to protect it, or use the ignition to disconnect a relay.
I have a larger 24/12-70 in the system, but using that would require a current limiter.
Thanks!
