a few months ago I bought a “Victron Smartsolar MPPT 75/10”, a 30W solar panel, and a 12V 9Ah AGM battery to test out. I’m running some sensors in my garden 24/7. In the summer, I also run a small sprinkler system based on a timer and the weather. So far, it’s worked absolutely brilliantly. The load of the sensors is 0.1 amps, the sprinkler more but does not run all the time. Currently, a bulk charge is performed every morning to compensate for the losses from the night, but after that, the battery is essentially charged all day.
Questions:
1.) Are there any issues with “overcharging the battery” or similar, especially in summer when the battery is actually charged/full all the time? Should I adjust settings here? Are there any problems I should be aware of, including with the small AGM battery?
2.) What settings/measures should I take to extend the battery’s lifespan, if necessary? I would now assume that summer/winter should be treated differently
The "Victron Smartsolar MPPT 75/10 is currently more or less on standard settings.
I changed the following:
-The recommended charging current of the battery is 0.9 A, I set 1 Ampere in the Victron
-I selected the battery type “AGM Spiral Cell.” I don’t know if that’s the correct choice, it’s an AGM supply battery.
-The battery’s charging voltage according to the datasheet is 13.8 to 14.4 V. I set the absorption voltage in the Victron to 14.4 V and the float to 13.8 V. No other settings were made.
-The device is set to shut off the load output at 12V battery voltage, should it ever get that low. I’ll have to test it out in the winter. I treated the short-circuit plug according to the manual.
Greetings
