I have a customer with an off grid system that has been installed for some years with a MP2 5000VA inverter. Histotrically they powered mainly lights, heating pumps and had an immersion set up as a rudimentary opportunity load (OL) switched via inverter settings and the relay on the MP2.
They have recently added a large home extension with a variety of new appliances including an induction hob, oven, more lighting, washing machine (hot fill) and dishwasher, max. individual load of 2.9kW on a 13A plug top or fused spur. They are well aware of the limitation on multiple devices not being used together but my conundrum is how to automate the immersion (3kW) now that with any two devices running there is a chance of long term overload.
I am more familiar with Nodered since I configured the original system and have set up a few systems with smallish immersions of c.1kW switched via shelly relays with nodered control. Still not quite able to conceive how to manage the overload and load shedding issues with that route.
Now the Shelly integration is here it looks like that has been dealt with, but I’m still after some clarification.
At 20.6.1 in the documentation ( 20. GX Opportunity Loads ) it does describe that if a large load switches on then the algorithm will switch off the load based on the timer function set and other parameters but how long can the MP2 deliver say 6kW if the immersion is on as an OL and the induction hob is then switched on?
The data sheet for the MP2 5000 that 9000W is possible for short periods, how comfortable is this headroom in order to allow controlled behaviour? When setting the reserve, does Venus know that you have a MP2 5000 or do you need to tell it the capacity of the system. I couldn’t find a reference to that in the documentation.
NB, for this example the really big loads VA=kW.
Anyone who has been considering some of the real world applications of this with limited or evolving systems please chime in! One option is obviously to upgrade the MP2 to the 8000VA version but I’d like to explore the solutions with the current setup as I expect their budget has been decimated by the recent build.
