5x Feature Request Vesus OS Opportunity Loads
Hello
I started setting up the Opportunity Loads in November, right on the delivery date of my EVCS. I currently have one EVCS and three heating elements integrated.
When programming the heating element control in NodeRed — especially during debugging — I was missing an “OPL view” in the GUI. I did build my own view for the heating control/monitoring, but during the DEBUG phase it wasn’t always very informative, particularly when OPL hadn’t enabled the load but NodeRed had still switched on the heating elements because of an error on my part.
My heating control view
Based on this and other experiences with OPL Loads, I have the following change requests:
  1. Make OPL status and decision reasons visible
  • A dedicated OPL status page in the GX and Remote Console should clearly show which loads OPL is currently enabling or blocking, and why.
  • For each load, the OPL request, the actual device status and the decisive reason should be displayed separately. For example: SOC below the enable threshold, battery charging taking priority, insufficient available power, inverter power limit or another load taking priority. Active SOC probing should also be visible.
  • The display should be clear: Green = enabled, red = blocked, grey = no communication or status unknown. An external block on a load, such as one caused by temperature control, should be distinguishable from the energy-related OPL decision.
Goal: Understand switching behaviour and troubleshoot issues without having to guess at the internal decision based on SOC, power values and relay states.
  1. Adjust OPL SOC thresholds based on weather and PV yield forecasts
  • The SOC threshold for enabling Opportunity Loads should optionally be adjusted dynamically and automatically based on the expected PV generation over the coming days.
  • When the yield forecast is good, lower-priority loads may be enabled at a lower SOC, provided the expected energy is sufficient to subsequently charge the battery to the desired target SOC. When the yield forecast is poor, battery charging should remain a priority for longer, leaving a higher reserve for powering the home.
  • The PV yield forecast, current SOC, usable battery capacity and expected base consumption should be taken into account. The minimum reserve and desired target SOC should be configurable by the user. Any permitted battery support for OPL must be limited by an explicitly configurable lower SOC threshold.
  • The currently calculated enable threshold and the reason for it should be visible on the OPL status page. If the forecast is unavailable or out of date, a configurable fixed SOC threshold should apply.
  • All energy decisions should remain entirely within Victron OPL; additional SOC control in Node-RED should not be required.
Goal: Make better use of available solar energy while preserving the required autonomy reserve ahead of days with low yields.
3. Integrate DC loads into Opportunity Loads
In addition to AC loads, Opportunity Loads should be able to selectively enable and control DC loads. This has practical applications, particularly in vans and motorhomes:
  • Trickle-charging the vehicle battery via an Orion DC/DC charger: OPL grants permission either via a control signal to the remote input or by fully switching the charger on and off. I have already implemented this solution in a lorry using option B, as the user wanted a lorry without Bluetooth or Wi-Fi.
  • Heating water with DC heating elements: Surplus solar energy is used to heat the water in a DC boiler once the supply and charging of the leisure battery are sufficiently assured.
  • Enable a DC-DC charger to charge the batteries of e-bikes.
DC loads should have their own priorities and enable conditions, just like AC loads, and be included in the shared power balance. They should be controllable via supported device interfaces or GX relays. Their status and decision reasons should also appear on the OPL status page.
Goal: Make good use of solar surplus on the DC side too — particularly in vehicles, without having to run the inverter.
4. Configurable grace period for insufficient power for virtual loads
As with the EVCS “Battery/Grid power timeout”, OPL should offer a configurable grace period for each virtual load.
If the available solar power falls below the demand of a load that is already switched on, it should be allowed to continue running for the configured period. The power shortfall is temporarily made up from the battery or — if permitted — from the grid.
If sufficient solar power returns, the timer is reset. If the power deficit persists, OPL switches off the load once the time has elapsed. Mandatory lower SOC limits and system limits take precedence. The running timer and remaining time should be visible on the OPL status page.
Goal: Ride out brief cloud cover or temporary load peaks without switching off loads immediately.
5. Configurable minimum run time for each load
It should be possible to set an individual minimum run time for each OPL load. After being switched on, the load remains active for at least this duration, even if short-term changes in available power would normally trigger it to be switched off.
The minimum run time starts when the load is switched on. Mandatory lower SOC limits, overload protection and device-side shutdown conditions take precedence. Any remaining minimum run time should be displayed on the OPL status page.
When a grace period is also in use, the two timers should work together clearly: a normal shutdown due to insufficient power should only occur once both conditions allow it.
Goal: Prevent frequent switching on and off (“relay tango”) and enable operation that is appropriate for the load in question.
That’s all for now, thanks for reading.
Phil
