Hi community,
I recently purchased an used VICTRON Phoenix Compact 12/1200 inverter.
The inverter seems to work fine, although I am having trouble to activate the “search mode” (not the ECO-mode, this mode is working fine)
It seems that the manual from the victron homepage is not 100% applicable to my inverter version.
E.g. when i adjust the DIP-settings (search mode @ DIP#6?) and safe them by switching DIP8 to OFF->ON->OFF all 3 LEDs light up once (to confirm the setting?)
The manual says the leds should blink up four times.
The Board (see picture) seems to be a little different as well, compared to current versions.
Its not eqipped with a second RJ45 port.
The front-plate of the case is different as well. The label is located on the bottom, not in the middle like currently available compact’s.
Does have anyone a proper manual for my inverter? (Yes I already browsed through all the new and old manuals in the Victron homepage) Or any advice how to turn on the search mode? I hope my inverter-version has an search mode. Its crucial for my application, since its very energy safeing.
Thanks in advance,
DoM1
