I have 2 pics of 48v/5000 phoenix Victron inverter cannot invert only flashing green light, I need solution to fix it.
Please add some more information about your system.
Is the Phoenix a new Smart one with VE.direct and Bluetooth or the old model with VE.Bus?
If it’s Smart you could use VictronConnect to see what’s going on.
If it’s one with VE.Bus you need a MK3 Interface.
They are used Victron Inverters, I have two pics of it and they have the same problem of flashing green light when powered on. I bought them in Germany.
Did you connect them together via VE.Bus?
If yes they need to be configured to work together.
Do they work one by one?
Yes, I think it was configured to work in parallel or 3-phase , now I want it configured to work as a stand-alone. the blinkg green light suggest the inverters are in a search mode.
