Node red show parallel system stats
Copying the post from the archive:
I wanted to share a flow I created that shows master and slave inverter stats, and any imbalances.
You will need to edit the “cerbo” mqtt endpoint to point to the IP of your own system or just use localhost (127.0.0.1).
Device ID’s are fixed values for every installation. See the note in the flow. The defaults for single (L1) phase will work.
Additional phases can be added using the mapping provided.
The flow uses dashboard 2.0 (flowfuse/node-red-dashboard) but you can replace those nodes with dash 1.0.
At low power the inverters may track high imbalances, this is especially true for AC IN if you are maintaining a low setpoint. It should show a representative value under load.
When working it should look like this:
Here is the flow:
        "id": "af466230632ad910",
        "type": "tab",
        "label": "Parallel L1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "76406dc6e7e04f2b",
        "type": "ui-text",
        "z": "af466230632ad910",
        "group": "93e86f6a5912e02d",
        "order": 6,
        "width": 0,
        "height": 0,
        "name": "L1 Slave AC OUT",
        "label": "L1 Slave AC OUT (W)",
        "format": "{{msg.payload}}",
        "layout": "row-spread",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#717171",
        "wrapText": false,
        "className": "",
        "x": 530,
        "y": 180,
        "wires": []
        "id": "a67391c82331d181",
        "type": "ui-text",
        "order": 5,
        "width": 0,
        "height": 0,
        "name": "L1 Master AC OUT",
        "label": "L1 Master AC OUT (W)",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#717171",
        "wrapText": false,
        "className": "",
        "x": 530,
        "y": 240,
        "wires": []
        "id": "c5a5dd36f002a701",
        "type": "ui-text",
        "order": 4,
        "width": 0,
        "height": 0,
        "name": "L1 Slave AC IN",
        "label": "L1 Slave AC IN (W)",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#717171",
        "wrapText": false,
        "className": "",
        "x": 520,
        "y": 300,
        "wires": []
        "id": "6b93b71f638181ed",
        "type": "ui-text",
        "order": 3,
        "width": 0,
        "height": 0,
        "name": "L1 Master AC IN",
        "label": "L1 Master AC IN (W)",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#717171",
        "wrapText": false,
        "className": "",
        "x": 520,
        "y": 360,
        "wires": []
        "id": "2fd15a2be5c55233",
        "type": "function",
        "name": "calc delta",
        "func": "var master = flow.get(\"MACOUT\");\nvar slave = flow.get(\"SACOUT\");\nvar delta = master - slave;\nvar total = master + slave;\nif (delta < 0) {\n    delta = slave - master;\n}\nvar perc = (delta/total)*100;\nmsg.payload = perc.toFixed(0);\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 320,
        "y": 540,
        "wires": [
                "963907f37327c2a1"
        "id": "53ecadfcb64d4205",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 170,
        "y": 540,
        "wires": [
                "2fd15a2be5c55233"
        "id": "efb8a0149eecb44a",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "MACOUT",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 100,
        "wires": [
        "id": "9fb61f21a877dcaa",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "SACOUT",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 60,
        "wires": [
        "id": "963907f37327c2a1",
        "type": "ui-gauge",
        "name": "Parallel imbalance",
        "order": 2,
        "value": "payload",
        "valueType": "msg",
        "width": 0,
        "height": 0,
        "gtype": "gauge-half",
        "gstyle": "needle",
        "title": "Output imbalance",
        "units": "%",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "8",
                "color": "#ffc800"
                "from": "16",
                "color": "#ea5353"
        "min": 0,
        "max": "20",
        "sizeThickness": 16,
        "sizeGap": 4,
        "sizeKeyThickness": 8,
        "styleRounded": true,
        "styleGlow": false,
        "className": "",
        "x": 570,
        "y": 540,
        "wires": []
        "id": "690e79ed2160cf69",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "MACIN",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 500,
        "y": 480,
        "wires": [
        "id": "2c358cbfb3088750",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "SACIN",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 500,
        "y": 420,
        "wires": [
        "id": "e032d9f7800ca055",
        "type": "function",
        "name": "calc IN delta",
        "func": "var master = flow.get(\"MACIN\");\nvar slave = flow.get(\"SACIN\");\nvar delta = Math.abs(master - slave);\nvar total = Math.abs(master) + Math.abs(slave);\nvar perc = (delta/total)*100;\nmsg.payload = perc.toFixed(0);\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 330,
        "y": 600,
        "wires": [
                "d9dcfee5b8f91221"
        "id": "095569a80c1ac60a",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 170,
        "y": 600,
        "wires": [
                "e032d9f7800ca055"
        "id": "d9dcfee5b8f91221",
        "type": "ui-gauge",
        "name": "Input imbalance",
        "order": 1,
        "width": 0,
        "height": 0,
        "gstyle": "needle",
        "title": "Input imbalance",
        "units": "%",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#5cd65c"
                "from": "30",
                "color": "#ffc800"
                "from": "60",
                "color": "#ea5353"
        "min": 0,
        "max": "100",
        "sizeGap": 4,
        "styleGlow": false,
        "className": "",
        "x": 560,
        "y": 600,
        "wires": []
        "id": "107682690189825e",
        "type": "victron-input-custom",
        "service": "com.victronenergy.vebus/276",
        "path": "/Devices/3/Ac/Out/P",
        "serviceObj": {
            "name": "Nuclear Reactor (276)"
        "pathObj": {
            "name": "/Devices/3/Ac/Out/P",
            "type": "number",
            "value": 717
        "onlyChanges": false,
        "roundValues": "0",
        "x": 200,
        "y": 160,
        "wires": [
                "76406dc6e7e04f2b",
                "9fb61f21a877dcaa"
        "id": "e278c4827acd63aa",
        "path": "/Devices/0/Ac/Out/P",
        "serviceObj": {
        "pathObj": {
            "name": "/Devices/0/Ac/Out/P",
            "type": "number",
            "value": 613
        "roundValues": "0",
        "x": 210,
        "y": 240,
        "wires": [
                "a67391c82331d181",
                "efb8a0149eecb44a"
        "id": "2c33f62af1fe7949",
        "path": "/Devices/3/Ac/In/P",
        "serviceObj": {
        "pathObj": {
            "name": "/Devices/3/Ac/In/P",
            "type": "number",
            "value": 0
        "roundValues": "0",
        "x": 200,
        "y": 300,
        "wires": [
                "c5a5dd36f002a701",
                "2c358cbfb3088750"
        "id": "320757b9dd9ed716",
        "path": "/Devices/0/Ac/In/P",
        "serviceObj": {
        "pathObj": {
            "name": "/Devices/0/Ac/In/P",
            "type": "number",
            "value": 0
        "roundValues": "0",
        "x": 200,
        "y": 360,
        "wires": [
                "6b93b71f638181ed",
                "690e79ed2160cf69"
        "id": "2e7ded39964f02bb",
        "type": "comment",
        "name": "Device ID order for Multis and Quattros",
        "info": "L1 Master 0\nL1 Slave1 3\nL1 Slave2 6\nL1 Slave3 9\nL2 Master 1\nL2 Slave1 4\nL2 Slave2 7\nL2 Slave3 10\nL3 Master 2\nL3 Slave1 5\nL3 Slave2 8\nL3 Slave3 11",
        "x": 170,
        "y": 80,
        "wires": []
        "id": "4098f447ca28b495",
        "type": "ui-chart",
        "name": "L1 AC OUT balance",
        "label": "L1 AC OUT balance",
        "order": 9007199254740991,
        "chartType": "doughnut",
        "category": "series",
        "categoryType": "property",
        "xAxisLabel": "",
        "xAxisProperty": "inverter",
        "xAxisPropertyType": "property",
        "xAxisType": "radial",
        "xAxisFormat": "",
        "xAxisFormatType": "auto",
        "xmin": "",
        "xmax": "",
        "yAxisLabel": "",
        "yAxisProperty": "power",
        "yAxisPropertyType": "property",
        "ymin": "",
        "ymax": "",
        "bins": 10,
        "action": "replace",
        "stackSeries": false,
        "pointShape": "circle",
        "pointRadius": 4,
        "showLegend": true,
        "removeOlder": 1,
        "removeOlderUnit": "3600",
        "removeOlderPoints": "",
        "colors": [
            "#0095ff",
            "#ff7f0e",
            "#ff7f0e",
            "#2ca02c",
            "#a347e1",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "textColor": [
            "#666666"
        "textColorDefault": true,
        "gridColor": [
            "#e5e5e5"
        "gridColorDefault": true,
        "width": "3",
        "height": "3",
        "className": "",
        "interpolation": "linear",
        "x": 640,
        "y": 660,
        "wires": [
        "id": "05b3cd7a4fa49669",
        "type": "function",
        "name": "Format chart",
        "func": "var master = flow.get(\"MACOUT\");\nvar slave = flow.get(\"SACOUT\");\n\nmsg.payload = {};\nmsg.payload = {};\nmsg = { \"payload\": [{\n    \"series\" : \"L1 Power\",\n    \"inverter\": \"Master\", \n    \"power\": master },\n    {\"series\" : \"L1 Power\",\n    \"inverter\": \"Slave\", \n    \"power\": slave\n}]\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 390,
        "y": 660,
        "wires": [
                "4098f447ca28b495"
        "id": "d392ad592cfffeef",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 170,
        "y": 660,
        "wires": [
                "05b3cd7a4fa49669"
        "id": "acea9df5e2d0fb1b",
        "type": "ui-chart",
        "name": "L1 AC IN balance",
        "label": "L1 AC IN Balance",
        "xAxisLabel": "",
        "xAxisFormat": "",
        "xmin": "",
        "xmax": "",
        "yAxisLabel": "",
        "ymin": "",
        "ymax": "",
        "bins": 10,
        "pointRadius": 4,
        "showLegend": false,
        "removeOlder": 1,
        "colors": [
            "#0095ff",
            "#ff7f0e",
            "#ff7f0e",
            "#2ca02c",
            "#a347e1",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "textColor": [
            "#666666"
        "gridColor": [
            "#e5e5e5"
        "width": "3",
        "height": "3",
        "className": "",
        "x": 630,
        "y": 720,
        "wires": [
        "id": "6f37874711cc944c",
        "type": "function",
        "name": "format chart",
        "func": "var master = flow.get(\"MACIN\");\nvar slave = flow.get(\"SACIN\");\n\nmsg.payload = {};\nmsg.payload = {};\nmsg = { \"payload\": [{\n    \"series\" : \"L1 Power\",\n    \"inverter\": \"Master\", \n    \"power\": master },\n    {\"series\" : \"L1 Power\",\n    \"inverter\": \"Slave\", \n    \"power\": slave\n}]\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 390,
        "y": 720,
        "wires": [
                "acea9df5e2d0fb1b"
        "id": "b360957c1fc7d251",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 170,
        "y": 720,
        "wires": [
                "6f37874711cc944c"
        "id": "5941c96ce50a5fa1",
        "type": "function",
        "name": "Chart inverters",
        "func": "msg.payload = {};\nvar masterin = flow.get(\"MACIN\");\nvar slavein = flow.get(\"SACIN\");\nvar masterout = flow.get(\"MACOUT\");\nvar slaveout = flow.get(\"SACOUT\");\nvar deltaout = Math.abs(masterout - slaveout);\nvar deltain = Math.abs(masterin - slavein);\n\nmsg = { \"payload\": [{\n    \"series\" : \"AC OUT imbalance\",\n    \"y\" : deltaout\n},{\n    \"series\" : \"AC IN imbalance\",\n    \"y\" : deltain\n},{\n    \"series\" : \"Master IN\",\n    \"y\" : masterin\n},{\n    \"series\" : \"Slave IN\",\n    \"y\" : slavein\n},{\n    \"series\" : \"Master OUT\",\n    \"y\" : masterout\n},{\n    \"series\" : \"Slave OUT\",\n    \"y\" : slaveout\n}]\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 380,
        "y": 780,
        "wires": [
                "cab2172cb8138722"
        "id": "5b8f182e6bee161a",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "30",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 170,
        "y": 780,
        "wires": [
                "5941c96ce50a5fa1"
        "id": "cab2172cb8138722",
        "type": "ui-chart",
        "group": "90a5c95cd3c30a40",
        "name": "Inverter Balance",
        "label": "Inverter power and deviation",
        "order": 6,
        "chartType": "line",
        "xAxisLabel": "Time",
        "xAxisProperty": "",
        "xAxisType": "time",
        "xAxisFormat": "",
        "xmin": "",
        "xmax": "",
        "yAxisLabel": "Power (W)",
        "yAxisProperty": "y",
        "ymin": "-9000",
        "ymax": "9000",
        "bins": "",
        "action": "append",
        "pointRadius": "2",
        "showLegend": true,
        "removeOlder": "24",
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "textColor": [
            "#666666"
        "gridColor": [
            "#e5e5e5"
        "width": "8",
        "height": "7",
        "className": "",
        "x": 640,
        "y": 780,
        "wires": [
        "id": "93e86f6a5912e02d",
        "type": "ui-group",
        "name": "Parallel stats",
        "page": "1f3f6aba836b135f",
        "width": "3",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "90a5c95cd3c30a40",
        "type": "ui-group",
        "name": "Charts",
        "width": "8",
        "height": "1",
        "order": 3,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "1f3f6aba836b135f",
        "type": "ui-page",
        "name": "Home",
        "ui": "20a0d5584e491036",
        "path": "/page1",
        "icon": "Home",
        "layout": "grid",
        "theme": "199c1371468ee29c",
        "order": 1,
        "className": "",
        "visible": true,
        "disabled": false
        "id": "20a0d5584e491036",
        "type": "ui-base",
        "name": "Home",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false
        "id": "199c1371468ee29c",
        "type": "ui-theme",
        "name": "Default",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094ce",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
Click the link to download.
26/7 updated to add donut chart and line chart that graphs 24 hours of data.
Hi!
I have 2 Multis in parallel, but there is no option on the dropdown menu to Devices AC IN or OUT
What firmware/GX version are you on?
If you have established the ID’s of your system from the GX, it really should be there:
OS 3.14… Node Red 3.0.2
Edit: I’ve just checked another system with latest firmware and this option is there… so I might have to update
Definitely need to update.
Updated.
Ubuntu radar charts are super compact and fast for humans to recognize imbalance by its shape. Wether its the imbalance between parallel devices or the 3 phases where the diagram equals the wye / delta vectors. Our public grid shows hardly any differences for the voltages why they are zoomed in to see anything.
[{"id":"86be145731acd277","type":"victron-input-gridmeter","z":"a9b943e599c9cad0","service":"com.victronenergy.grid/40","path":"/Ac/L1/Voltage","serviceObj":{"service":"com.victronenergy.grid/40","name":"eHZ18"},"pathObj":{"path":"/Ac/L1/Voltage","type":"float","name":"L1 Voltage (V)"},"name":"ABB","onlyChanges":false,"roundValues":"1","x":130,"y":3100,"wires":[["166d4941cbb3e356"]]},{"id":"2b35633c7f2eb11d","type":"victron-input-gridmeter","z":"a9b943e599c9cad0","service":"com.victronenergy.grid/40","path":"/Ac/L1/Voltage","serviceObj":{"service":"com.victronenergy.grid/40","name":"eHZ18"},"pathObj":{"path":"/Ac/L1/Voltage","type":"float","name":"L1 Voltage (V)"},"name":"ABB","onlyChanges":false,"roundValues":"1","x":130,"y":3040,"wires":[["134e126146299568"]]},{"id":"915ba4a774f935f7","type":"victron-input-gridmeter","z":"a9b943e599c9cad0","service":"com.victronenergy.grid/40","path":"/Ac/L3/Voltage","serviceObj":{"service":"com.victronenergy.grid/40","name":"eHZ18"},"pathObj":{"path":"/Ac/L3/Voltage","type":"float","name":"L3 Voltage (V)"},"name":"ABB","onlyChanges":false,"roundValues":"1","x":130,"y":3160,"wires":[["a8be76bfefbfd7ed"]]},{"id":"134e126146299568","type":"function","z":"a9b943e599c9cad0","name":"Topic  U1","func":"msg.topic = \"U1\";\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":3040,"wires":[["eb2dafdb92402a9d"]]},{"id":"166d4941cbb3e356","type":"function","z":"a9b943e599c9cad0","name":"Topic  U2","func":"msg.topic = \"U2\";\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":3100,"wires":[["eb2dafdb92402a9d"]]},{"id":"a8be76bfefbfd7ed","type":"function","z":"a9b943e599c9cad0","name":"Topic  U3","func":"msg.topic = \"U3\";\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":3160,"wires":[["eb2dafdb92402a9d"]]},{"id":"eb2dafdb92402a9d","type":"join","z":"a9b943e599c9cad0","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"5","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":450,"y":3100,"wires":[["8e20bf9ebf0d4e5e"]]},{"id":"8e20bf9ebf0d4e5e","type":"function","z":"a9b943e599c9cad0","name":"Zoom","func":"let values = Object.values(msg.payload);\nlet min = Math.min(...values);\nlet zoom = 4;\n\nmsg1 = {\"payload\" : msg.payload.U1 - min + zoom,\n        \"topic\" : \"U1\"};\n\nmsg2 = {\"payload\" : msg.payload.U2 - min + zoom,\n        \"topic\" : \"U2\"};\n\nmsg3 = {\"payload\" : msg.payload.U3 - min + zoom,\n        \"topic\" : \"U3\"};\n\nreturn [msg1,msg2,msg3];\n","outputs":3,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":3100,"wires":[["4bdd318dc0ff5cfd"],["4bdd318dc0ff5cfd"],["4bdd318dc0ff5cfd"]]},{"id":"4bdd318dc0ff5cfd","type":"ui_chart","z":"a9b943e599c9cad0","name":"","group":"b7a9ced364d46a19","order":6,"width":0,"height":0,"label":"Netzspannung","chartType":"radar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":760,"y":3100,"wires":[[]]},{"id":"c4825e77b874eeb9","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/0/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/0/Ac/In/P","name":"/Devices/0/Ac/In/P","type":"number","value":-2883},"name":"Dev0","onlyChanges":false,"x":130,"y":3220,"wires":[["b12b0b1befc5da95"]]},{"id":"61e4b654a5373963","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/1/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/1/Ac/In/P","name":"/Devices/1/Ac/In/P","type":"number","value":-3003},"name":"Dev1","onlyChanges":false,"x":130,"y":3280,"wires":[["b12b0b1befc5da95"]]},{"id":"a14a9d3b066f8520","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/2/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/2/Ac/In/P","name":"/Devices/2/Ac/In/P","type":"number","value":-2951},"name":"Dev2","onlyChanges":false,"x":130,"y":3340,"wires":[["b12b0b1befc5da95"]]},{"id":"7532f4db58785c56","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/6/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/6/Ac/In/P","name":"/Devices/6/Ac/In/P","type":"number","value":-2256},"name":"Dev6","onlyChanges":false,"x":130,"y":3580,"wires":[["b12b0b1befc5da95"]]},{"id":"542ce0b02dbbf55d","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/7/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/7/Ac/In/P","name":"/Devices/7/Ac/In/P","type":"number","value":-2252},"name":"Dev7","onlyChanges":false,"x":130,"y":3640,"wires":[["b12b0b1befc5da95"]]},{"id":"3650aaf008eed654","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/8/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/8/Ac/In/P","name":"/Devices/8/Ac/In/P","type":"number","value":-2566},"name":"Dev8","onlyChanges":false,"x":130,"y":3700,"wires":[["b12b0b1befc5da95"]]},{"id":"f4881319e1175f02","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/3/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/3/Ac/In/P","name":"/Devices/3/Ac/In/P","type":"number","value":-2881},"name":"Dev3","onlyChanges":false,"x":130,"y":3400,"wires":[["b12b0b1befc5da95"]]},{"id":"d5d45000aa7e88cf","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/4/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/4/Ac/In/P","name":"/Devices/4/Ac/In/P","type":"number","value":-2780},"name":"Dev4","onlyChanges":false,"x":130,"y":3460,"wires":[["b12b0b1befc5da95"]]},{"id":"7dd84a56f82dfdaa","type":"victron-input-custom","z":"a9b943e599c9cad0","service":"com.victronenergy.vebus/276","path":"/Devices/5/Ac/In/P","serviceObj":{"service":"com.victronenergy.vebus/276","name":"MultiPlus-II 48/5000/70-50 (276)"},"pathObj":{"path":"/Devices/5/Ac/In/P","name":"/Devices/5/Ac/In/P","type":"number","value":-2519},"name":"Dev5","onlyChanges":false,"x":130,"y":3520,"wires":[["b12b0b1befc5da95"]]},{"id":"b12b0b1befc5da95","type":"join","z":"a9b943e599c9cad0","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"6","count":"9","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":350,"y":3460,"wires":[["d6600a2ae935f886"]]},{"id":"52443402eda149d5","type":"ui_chart","z":"a9b943e599c9cad0","name":"","group":"5d6aa5fa2cd38a95","order":6,"width":0,"height":0,"label":"L1","chartType":"radar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":730,"y":3460,"wires":[[]]},{"id":"d6600a2ae935f886","type":"function","z":"a9b943e599c9cad0","name":"Topics Dev1-8","func":"msg1 = {\"payload\" : msg.payload.Dev0 *-1,\n        \"topic\" : \"L1Master\"};\n\nmsg2 = {\"payload\" : msg.payload.Dev1 *-1,\n        \"topic\" : \"L1Slave1\"};\n\nmsg3 = {\"payload\" : msg.payload.Dev2 *-1,\n        \"topic\" : \"L1Slave2\"};\n\nmsg4 = {\"payload\" : msg.payload.Dev3 *-1,\n        \"topic\" : \"L2Master\"};\n\nmsg5 = {\"payload\" : msg.payload.Dev4 *-1,\n        \"topic\" : \"L2Slave1\"};\n\nmsg6 = {\"payload\" : msg.payload.Dev5 *-1,\n        \"topic\" : \"L2Slave2\"};\n\nmsg7 = {\"payload\" : msg.payload.Dev6 *-1,\n        \"topic\" : \"L3Master\"};\n\nmsg8 = {\"payload\" : msg.payload.Dev7 *-1,\n        \"topic\" : \"L3Slave1\"};\n\nmsg9 = {\"payload\" : msg.payload.Dev8 *-1,\n        \"topic\" : \"L3Slave2\"};\n\nreturn [msg1,msg2,msg3,msg4,msg5,msg6,msg7,msg8,msg9];\n","outputs":9,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":3460,"wires":[["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"],["52443402eda149d5"]]},{"id":"b7a9ced364d46a19","type":"ui_group","name":"Spalte4","tab":"52c4a1be8450fe1a","order":5,"disp":false,"width":"6","collapse":false,"className":""},{"id":"5d6aa5fa2cd38a95","type":"ui_group","name":"Spalte1","tab":"52c4a1be8450fe1a","order":1,"disp":false,"width":"6","collapse":false,"className":""},{"id":"52c4a1be8450fe1a","type":"ui_tab","name":"Gottlieb-Daimler-Microgrid","icon":"dashboard","disabled":false,"hidden":false}]
Unfortunately radar charts aren’t part of dash 2.0 and I don’t use dash 1 any longer.
I have tested using donut charts instead to visualise, if anyone finds value in that I will add it to the flow.
Updated to add:
Donut charts.
24-hour historical chart (30-second sample, adjust as required)
Adjust the min/max chart scale for better visibility.
