Doubt the last digit is anything valid. This are simply rounding errors converting the integer into IEEE 754 float format by node.js
Here is a photo of my ABB. Photo shows RS485 where A and B are not always inverted and non inverted signal or plus and minus. Every manufacturer counts different. But both digits behind comma are exactly same between Murata offline instrument, ABB and Ziehl EFR. For the Ziehl I polled with a frequency of 1 Hz by Modbus TCP using Sunspec register 40096. Anyhow, NodeRed is not sufficient to show long term diagrams. After several minutes data amount gets too high for a Cerbo and needs to be transfered to anything like InfluxDB, SQL to Grafana.
The 0,01 Hz diagrams were pretty in center of 50 Hz. Some full hours we can recognize a peak of about 100mHz up or down for 2-3 minutes before compensated
