I’m running Node-RED on Cerbo GX.
Sometimes, node-red crashes and restarts:
@4000000067a619e922cf2fac <--- Last few GCs --->
@4000000067a619e922cf377c
@4000000067a619e922cf3b64 [13222:0x2502f10] 835753808 ms: Scavenge 230.6 (255.7) -> 229.7 (255.7) MB, 2.8 / 0.0 ms (average mu = 0.973, current mu = 0.977) allocation failure;
@4000000067a619e922cf4eec [13222:0x2502f10] 835753885 ms: Scavenge 230.6 (255.7) -> 230.0 (255.7) MB, 10.2 / 0.0 ms (average mu = 0.973, current mu = 0.977) allocation failure;
@4000000067a619e922cf665c [13222:0x2502f10] 835754017 ms: Scavenge 230.6 (255.7) -> 230.5 (257.7) MB, 41.1 / 0.0 ms (average mu = 0.973, current mu = 0.977) allocation failure;
@4000000067a619e922d1d374
@4000000067a619e922d1d75c
@4000000067a619e922d1db44 <--- JS stacktrace --->
@4000000067a619e922d1e314
@4000000067a619e922d1e6fc FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
@4000000067a619e939d876cc *** starting node-red-venus ***
@4000000067a619ea0011e414 *** Waiting for localsettings...
@4000000067a619ea018dd1cc *** Starting in normal mode
@4000000067a619f0018d3974 [info]: loading /data/home/nodered/.node-red/settings-venus.js failed
@4000000067a619f001f21d94 [info]: loading /data/home/nodered/.node-red/settings-user.js failed
@4000000067a619f119e75af4 7 Feb 15:34:15 - [info]
@4000000067a619f119e77a34
@4000000067a619f119e78204 Welcome to Node-RED
@4000000067a619f119e785ec ===================
@4000000067a619f119e78dbc
@4000000067a619f11a5700fc 7 Feb 15:34:15 - [info] Node-RED version: v3.1.10
@4000000067a619f11a85f86c 7 Feb 15:34:15 - [info] Node.js version: v18.20.3
@4000000067a619f11aa1d53c 7 Feb 15:34:15 - [info] Linux 5.10.109-venus-17 arm LE
@4000000067a619f405c26744 7 Feb 15:34:18 - [info] Loading palette nodes
@4000000067a61a0133ff552c 7 Feb 15:34:31 - [info] Dashboard version 3.2.0 started at /ui
I think the solution would be to add “–max-old-space-size=256” param in
/usr/bin/node-red-venus.sh
exec /usr/bin/node-red $safe --userDir "${NODE_RED}" --max-old-space-size=256 --settings /usr/lib/node_modules/node-red/venus-settings.js "$@"
Test if the setting is applied correctly:
root@einstein:~# node -e "console.log(v8.getHeapStatistics().heap_size_limit / 1024 / 1024 + ' MB')"
257.5 MB
