Node-red password reset
Seems node-red doesn’t recognize my password anymore. Last time I think I logged in was when I updated cerbo gx to Venus 3.62.
Is there a way to reset Password without loosing all my flows?
The username is admin, all lower case and password should be the same as you set to access your Cerbo under setting/general/access & security/local network security profile. Hopefully you recall this important password. You should be able to update it on the Cerbo at the above page but I expect that you will need your existing password.
If you can not do this, then the Cerbo has a reset button, Sectipn 4.4 of the manual has a section on lost password. This should not delete the flows.
I have bit warden with all my passwords saved, there’s no change log since it was added in 2024.
I do have cerbo password and node-red passwords.
I needed the cerbo password when I set up android tablet as screen. Hopefully when I get there in person I can figure it out.
I did try the cerbo password and it didn’t work. :face_with_diagonal_mouth:
Perhaps it predates this settings I noted above, there is older stuff saying it is the same as the remote console password. If the 2 passwords are different I am not sure how you can proceed. There is this topic.
Shoot I have a vague memory I had to reset a password for the cerbo when I set up tablet. Would that have reset node red as well?
I tried admin / admin and admin /cerbo password.
If you reset the Cerbo password then I expect that would update Node Red aswell.
I’ll have to look into this, bitwarden doesn’t show the password has changed since 2024 as well.
Self sabotage is not unusual for me though
Should that be the case how to I reinstall node-red?
Hopefully when I’m on local network I can get it sorted out.
You would go to the firmware update page and change from large image to standard image and upload that, then go back to large image and upload that. I have no idea if that clears all settings and deletes flows or if these end up being retained. I have some recollection that I removed Node Red at one time a few years ago and when I re-installed it the previous flow was still there.
Ok I’m in!
I couldn’t figure out the cerbo password, so I reset it. This is now the new node-red password.
No flows where lost!
Export your flows so you have a backup copy.
