Night-only battery charging from grid (time-restricted charging)
Good day.
I’ve run into a situation where I need to configure the inverter so that it charges the battery from the grid only at night.
Even if there is a power outage during the day and the battery discharges down to 30%, charging must not start earlier than 23:25 and must stop no later than 07:25.
Do you have a Cerbo or other GX device in your system? It would be possible to set this up with that.
Otherwise: You can install the 2 signal BMS assistant and use the charger control of that with any time switch with volt free contacts.
Hi, instaled Ekrano GX
If you install Venus large, then you should be bale to implement this with node red.
