Can i set the Cerbo GX to turn on the inverter when the batteries are fully charged
My caravan fridge has an Auto changeover Gas/240Volt, I’d like to use mains power to run my fridge when the batteries are charged, just to save on the gas use. I’ve got 600 Watts of solar, a 2000Watt Victron Smart Phoenix Inverter.
Can the Cerbo GX switch the inverter on when the batteries are charged?
Thanks for any help
That might require some Node red coding to work.
Many Thanks Paul.
I’m new to this and hadn’t heard of Node Red, I’ve had a quick look and I think I’ve got some homework to do!
No problem. We leave our MP2 an entire trip. A Shelly relay manages AC to the fridge by watching shore, solar, SOC & inverter load, etc. Another 2 manage water heater change over. NR and also MQTT can be addictive. Safe travels.
