Using latest beta version. When I open history on MPPT it shows strange scale for kWh, making it hard to read the chart.
Same for 14 days, while 7 day is more useful:
Chart was never working for me and doesn’t work on latest beta
How did you get there?
WHat version of Venus OS are you on?
v3.52~6
I open it via Overview page (touch on solar box) or from Settings → Device list → BlueSolar Charger.
Then History and change Today on the right to 7 / 14 / 31 days. Then Chart tab will become available. I also think this is not good usability and than Chart should be enabled and if user selects it, it should auto switch to 7 days.
I’m on the same version of Venus OS, but on my Smart MPPT 150/70 I can see only Today/Yesterday and Graph is always inactive in gui-v2
This is MultiRS system ^^^^^
On MultiPlus-II system below I see this dropdown
SmartSolar MPPT 250/70
EDIT:
Unrelated to MultiRS vs MultiPlus-II - I see this patter on different systems
Also: the “Table view” should be an actual table, not only showing the total.
A table view for the daily summary could be interesting to quite some users, I suspect…
Interesting, I still think Summary would be better tab name than Table view
Click open the drop down, then select something else than today or yesterday.
I only have today and yesterday in the drop down… even though I’ve been running gui 2.0 for at least 2 weeks now.
CAN has limited volume of data by design
I don’t understand what this means. Obviously there is some way to display a chart of the charge controllers history otherwise why is that tab there to begin with? Other people are clearly confused by this as well.
When you have VE.bus serial connection from MPPT to Cerbo - it will have dropdowns for 7-14-30 days and full width graph.
For devices, connected via VE.Can - data limited to just 2 days.
I have a 250/100 VE.Can and two 250/70 VE.Can. They are daisy chained and then go to the Cerbo GX. Are you saying I can’t chart the history then within the Venus OS UI with those charge controllers? I do see my 150/35 does show the other days in the dropdown and that is connected via VE.Direct.
True. Don’t know if this is going to be changed for VE Can
