I have been trouble shooting some strange behaviour on my N2K network and I believe I think I know the cause…have I created a network loop here:
The Cerbo and the Zeus are both connected to each other, but then they are both also connected to the Raymarine N2k network.
Should I remove the ethernet cable (red) between the Cerbo and the Zeus?
Also where do I put the blue/square terminators? There is only two ports on the Cerbo CanBus, one of which connects to the Multiplus.
If like the N2K network there should be a connector at each end, then I have one spare port on the cerbo, but I would also need two ethernet ports on the other end (Multiplus end?)
