VE.Can on Cerbo kills network
I have had some gremlins in my Raymarine N2K network which was causing the wind data to drop off for a few seconds out of every 10-20s. I got a new wind unit but it was still there so not that.
I started to look into my N2K (stNG) network and noticed the resistance was all over the show, jumping from 30-250 and everything in between, and in other parts of the network there was 0 resistance.
So I tested the network in segments and have found that it is the CerboGX and/or Azro Zeus (alternator regular which is also on CanBus) that is causing this. The CerboGX is plugged into the stNG with the Blue Victron cable.
As soon as I remove this cable from the stNG spur the readings are a steady 60 Ohms.
Has anyone seen this before?
I suppose next steps are check for open circuit on the cable on the data pins? same on the Cerbo?
If you need to do resistance / continuity checks on a CAN network (N2K) then everything must be powered down. Occasional data packets sent from a source will cause false readings. Apologies if this is obvious. The Cerbo if powered down should be loop through between the CAN ports (A-A,B-B) with no termination.
Ahh, I did not know this. I will test again tomorrow.
However the problem still points to the Cerbo and/or Zeus Regulator because when either or both of them are plugged in I loose my wind dirn/speed data for about 1 second in every 10-20 seconds
Tested again and with everything off it tests at 60Ohm across various test points.
did you ever solve this? I’ve got something similar happening on our boat
Nah, not yet. I think its a Zeus/Victron problem.
