My mppt not working?
Hi all, here is a question from a beginner: I I ave a victron batt charger mppt 75/10 which seems to be working in my
boat. The solar panel was connected and today it seems to be working. Lamp is blue and volt from panel is ok but no load is going to the battery. Why is that? What am I missing here? It says bulk…
Your PV voltage is too low. It needs to be 6V above the battery voltage to start
As Nick says, the PV voltage is too low, what panel are you using?
It’s a solarmare 50W mono 2.0.
When the solar panel is not connected the blue lamp is flashing. Why is that? When connected its a fixed light.
Ok, then I’ll wait until I have less Volt on the battery.
blue light always flashes when battery is on and pv is off. just so you know the unit is working…
Is no one going to ask why the battery is at 14.37V? Is there another charging source operating? Also, 16.18V is pretty low voltage for a solar panel even in cloudy weather. You may continue to have issues with getting it to work consistently.
