3-phase mulitplus2-8000 system, with all loads on AC1-Out, grid on AC-In, Fronius PV on AC1-Out, VenusOS 3.70.
As you can see in the below screenshot, Phase 2 and 3 on AC-Out apparently have same load, but wildly different
amperage values. Generally, the multiplus on Phase 2 behaves a bit weird; both L2 and L3 usually have identical load, but while L3 does consume a bit from the grid, L2 is constantly feeding back to it; in the past both L2 and L3 fed back to the grid to compensate for L1,
ESS grid setpoint is at +30W.
The screenshot was taken with all PV off and the heat-pump on, which consumes about 900W/phase. The rest of L1 is most of the house.
Any idea what might be the case here? I get the feeling this started with the update to 3.70, previously it has been rock-solid.
Thanks!
Manuel
