Multiplus2-GX update with Cerbo-GX
I updated my system with a Cerbo-GX V3.67:
Multiplus2 V507 GX 3.66, 4 MPPT, 2 Pylontech, EVCS, actually no critical loads.
Now the problem is, that the is shown critical load power, but ther is no load connected:
Also the battery shows this power, but I don’t believe it.
Do I have to disconnect the GX part in the Multi, when I connect a Cerbo GX with VE.bus?
Thanks
Gerd
So, I did it: I disconnected the GX-PCB inside of the Multi.
Then the display in the remote console oscillates a few kW from AC loads to critical loads in about 5 sec.
I think, these kW oscillates in real from and to the battery.
Should I update the Multi, if there exists a new firmware?
Gerd
You do need to update all the victron components.
Remember when the inverter firmware is updated it wipes settings , you will need to re program.
So, I updated the Multiplus to the version 5.58 and reconfigured all, but I have the same behaviour:
The AC loads and the critical loads are oscillating, even if there is no load connected.
What can I do?
Gerd
When I go back to the internal GX of the Multiplus II, all is stable and works correctly.
New information.
How thoroughly disconnected was it when the cerbo was running in the system?
