I have a multiplus 3k 2X120 12V and I have a 2000w shore input and it’s limited by the multiplus to 13A input. Often, the internal transfer switch on the multiplus opens and i’m on Inverter mode only and not pass thru or Assisting. I have checked all the settings I can’t figure out what is causing this. I switch off the shore input for a while and reconnect it and it then works for a while and then it transfers off it. WTF is going on? could it be a poor sine wave from shore? Is there any way to test if it’s the shore or the inverter is doing this?
Thank you for the reply. What specifically am I looking for on this screen? Or just mirror these settings? I do have mk3 and any operating system.
Click the Show IP (NS) protection log button right after an event occurs, it may tell you why.
What is your low voltage disconnect setting?
Also, the numbers on the left are live (UMains, IMains, etc.) when this is running, you might catch a low voltage situation.
I would NOT check “Accept wide input frequency” unless you are running off a generator.
I assume the shore power grid-based, and is stable.
Any change it is generator power from a central source?
Loose connection?
Can you plot the AC input voltage in VRM as well?
I have a pic but don’t need it. When the voltage goes to zero the HZ goes to zero also. Let me check for loose connection in the inverter input, but I doubt that. It runs just fine on generator on that input, so probably eliminates Victron’s friction connections to the inverter. But will check.
