Multiplus problem
Hello from a brand new member on here , i am hoping someone can help me with a question i have about my 24 volt 5000 / 120-16 multiplus regarding usage history , the reason is i bought this inverter over 12 months ago in a non working state and had it repaired by a guy who replaced the mossfets , the other day i took it out of the shed and wired it up to use it and when i turned on the inverter switch i could hear a relay going on off real fast and so i turned the unit off and back on and still hearing it , so then i turned it onto battery charge as it went into that mode i heard the relay again making its noise and then switch to inverter and then off , and now it wont even power on , so i am just wondering is there a history of use or anything like that to show the guy that i had not used it since picking it up from him all that time ago , i know the charge controllers have a history so wondered about the inverters .
Is there a hidden fuse under the top board ? some comments i read about a noisy relay points to loose connections as 1 possability ./
Thanks
No, the inverter does not store a useage history…
Thank you Mike for answering that question , just got to hope he does the decent thing and look at it and try and fix the issue with little or no extra cost .
