Multiplus not reporting AC input or output when on shore power
RV install:
BMV-712 Smart FW-v4.16
SmartSolar MPPT VE.Can 250/100 rev2 FW-v3.16
SmartSolar MPPT VE.Can 150/100 rev2 FW-v3.16
Cerbo GX FW-v3.54
MultiPlus-II 12/3000/120-50 120/240V FW-v552
(2) Epoch 12V 460Ah V1 Elite Series - Heated & Bluetooth & Victron Comms LiFePO4 Battery
In the winter I generally don’t use shore power. I’m getting the rig ready for the spring camping season and I’m seeing there is now no AC current/wattage in or out reported when the Multiplus is on. When it’s inverting it reports AC output fine. I have checked AC power is working in the rig. I’ve confirmed AC is coming in through shore power. Since the last time I saw it reporting correctly I did upgrade the firmware on the Multiplus from version ‘508’ to version '552 and have upgraded the Cerbo from version ‘3.50’ to version '3.52’. I’m observing this on the touch display, in VRM, and in VictronConnect. I hope this is a software issue.
Anyone else seen this or able to suggest further troubleshooting steps?
Try turning everything off at the shut-off and then restart everything.
