Multiplus | Maximum power without engaging the fan
Currently I have a small MultiPlus 12/500/20 and the internal cooling fan starts when an output power reaches about 100-150W.
I’m looking to buy a larger MultiPlus, probably MultiPlus-II GX 48/3000/35-32 or 48/5000/70-50,
and trying to choose a model to run without engaging the fan if possible.
Can anyone share at what load does the inernal fan start in these models:
MultiPlus-II GX 48/5000/70-50
FYI
There is a assistant (silence fan) you can install on your MP who “disables” the fan.
It automatically throttles down the output when temperature becomes to high.
Overview of available Assistants [Victron Energy].
I have a MP 48/500/70 and I set the max charge/discharge limit during the night to 1000W to prevent the fan to kick in. Using a simple nodered flow.
Thank you for the insight!
I’ve read about “Silence fan” before, but the wording of this message
was a bit vague (no concrete specs),
and I wasn’t sure how higher temperature (without a fan) can affect the Multiplus’ longevity,
so didn’t risk to use it for a prolonged time.
Does anyone have any info about the fan in the MultiPlus-II GX 48/3000/35-32?
I’ve hoped to find something like this PC PSU chart:
or at least something like “The fan starts when the output power reaches XXX W (at YY °C)”.
Can anyone from Victron provide such specs?
I suppose that this can be changed in the firmware later(?), but what about the current threshold?
Derating depends on ambient as well. Orientation of the inverter etc. so set up specific.
The data cannot be made sepcific to your set up.
You can use a cerbo and a temp sensor and see it that way. In vrm advanced with a custom widget you will be able to track data
