My MultiPlus II 48/5000/70-50 does not supply power to the DC loads. Is this normal and expected behavior? Or do I have something misconfigured?
I believe my system setup is somewhat unusual, which might be causing the issue.
Here’s my system configuration: three-phase 3x400V supply protected by a 32A breaker. One MultiPlus II 48/5000/70-50 is installed on phase L1, configured with the ESS assistant. On the grid side, I have a VM-3P75CT meter installed so that the system can correctly measure loads located before the MultiPlus AC-IN. Several backup loads are connected to AC-OUT 1, while the rest of the loads are on the AC-IN side. The AC-OUT 2 output is not connected.
The system includes photovoltaic sources on both the AC-IN side of the MultiPlus (two Hoymiles microinverters on phases L2 and L3) and the DC side, where one SmartSolar MPPT 150/100 is used. Everything works great — I have no complaints about the ESS operation. The DC-coupled PV - feed in excess option is enabled and functioning well. Additionally, the ESS is configured with a Grid Set Point of -10W, which it maintains most of the time without issues.
The problem appears under specific conditions. When the battery state of charge (SOC) drops to the minimum level set in the ESS settings, the MultiPlus starts powering all loads directly from the grid — as expected.
The issue is on the DC side. The MultiPlus does not supply power to DC loads, allowing the battery to discharge below the minimum SOC threshold. If the SOC drops about 5% below the minimum limit, the MultiPlus starts recharging the battery from the grid at the full charge current limit set in VE.Configure. This cycle can repeat 2–3 times per day.
In my system, many loads are connected directly to the main battery via a SmartShunt 500A, which is configured as a DC Load. The Cerbo nicely reports DC loads, which typically range from around 130W up to over 1000W at peak.
What should I configure so that when the battery reaches the minimum SOC threshold, the MultiPlus powers my DC loads from the grid instead?
