Multiplus charging mode with AC coupled PV inverter
Attached we see a setup from the Victron ESS handbook page 2. This typical ESS shows a grid connection (with or without EM540 counter) and AC coupled PV. There is intentionally no MPPT or other DC charger.
If grid fails, the Multi disconnects its INPUT and OUT1 connection goes offline. The supply of “essential AC loads” is not interrupted as the Multi inverter goes on to maintain the AC OUT1 from battery.
The shown (Fronius or other) grid inverter accepts the Multiplus OUT1 as public grid and goes on to feed in all available power from the modules. If “essential AC loads” are greater than power from the AC coupled grid inverter, missing power is automatically completed by the Multiplus from its battery source.
My question:
Assume essential AC loads are smaller than the power from the AC coupled grid inverter. Is the multiplus able to use this energy for charging its battery? Or will the Multiplus throttle the Grid inverter output by frequency shift or data link and waits to charge battery until the grid comes back?
No, the AC loads can be much larger. I.e. you can have a 600-W-grid inverter, and have 2000 W AC load. The MP2 will take whatever is needed either from the battery or from the grid. And yes: if your AC-load is smaller than what the PV-inverter delivers at the very same moment, the MP2 will load the battery with the excess power.
You don’t even need to connect the PV-inverter to the MP2’s AC-out . It can feed it’s power to the grid instead, but then you definitely need a power counter between grid and PV-inverter/MP2.
Thanks. Do you have any source of pdf manuals for this behaviour?
Pls. note, that the situation of question deals with failed grid connection. Thats why I have choosen the grid inverter connection to ESS OUT
With other words:
In AC Grid Inverter excess power, this power goes into the OUT1 terminal and is transfered to battery als long as this is not too near at 100% SOC.
On the other hand in grid operation, power comes out from the ESS input terminal to feed into the grid. This terminology of input and out directions is not really self explaining.
Yes thats how it works!
Why don’t you give Google a try with “Victron ESS manual”?
Oh yes. I assume that this has something to do with the history behind Victron products.They have their origins in camping and yachting.
Already readed the Victron ESS manual several times in English and also the poor German translation. E.g. see chapter 1.2. “Netzmesser” does not exist in German dicitionarys an is simply wrong translation by anything like Google. “Stromzähler” would be the correct translation what also appears in chapter 10.14. The situation equals the schematic on page 2 but behaviour is not described there explicitly. Maybe additional information could be collected from YT.
This shouldnt be any critics for Victron. I simply like to understand all the marvelous blue adult toys.
So why are you wasting the time of other forists by asking for a link for exactly these manuals?
And the German language has a very special feature, which makes it very precise, but also very difficult to understand for native speakers of other languages: compound words. You will probably never find the word “Donaudampfschifffahrtskapitänsmützenabzeichen” in a German dictionary :slight_smile: But it exists and every native speaker of German can understand it.
